ผู้เขียน หัวข้อ: [หมายศาลท้าดวล]V2 Assault Metalic Buster Gundam  (อ่าน 10953 ครั้ง)
ออฟไลน์ thebeer
  • กระทู้: 155
« เมื่อ: สิงหาคม 29, 2010, 08:40:28 pm »
General and Technical Data
Model number: LM314V23/24
Code Name: V2 Assault-Buster Gundam
Unit type: heavy attack use/defense mobile suit
Manufacturer: League Militaire
Operator: League Militaire
First deployment: UC 0153
Accommodation: pilot in panoramic/linear seat cocpit in torso with Core Block System using Core Fighter
Dimensions: head height: 15.5 meters
Weight: empty 14.5 metric tons;   gross 23.1 metric tons
Armor materials: gundarium alloy/super-ceramic composite ; additional anti-beam-coated external armor plates, ejectable
Powerplant: Minovsky type ultracompact fusion reactor, output rated at 7510 kW
Propulsion: Minovsky drive thrusters: 2 x 16700 kg; rocket thrusters: 7 x 4770 kg; vernier thrusters/apogee motors: 46
Performance: maximum thruster acceleration: unknown (possibly lower than standard LM314V21 Victory 2 Gundam due to additional armor plates)
Equipment and design features: sensors, range unknown; special weapons targeting sensor in head, can be deployed over right eye sensor/camera; 2 x I-field beam-deflecting barrier generator
Fixed armaments: 2 x vulcan gun, fire-linked, mounted in head in mobile suit mode and in main body of Core Fighter (operable while docked with Top Fighter and Bottom Fighter); 2 x beam saber, stored in recharge racks in forearms, hand-carried in use in mobile suit mode or on Top Fighter, 2 spare beam sabers stored in forearms; 2 x beam shield, mounted on forearms in mobile suit mode, also operable on Top Fighter; 10 x hardpoint, can be used to externally store beam rifles or beam pistols, 4 located on arms in mobile suit mode and on main body of Top Fighter, 2 located on hip armor in mobile suit mode and on main body of Top Fighter, 4 located on legs in mobile suit mode and on main body of Bottom Fighter; multi-launcher, location unknown; mega beam cannon, mounted on backpack over right shoulder; 2 x VSBR (Variable Speed Beam Rifle), selectable mega particle acceleration speed for damage or penetration application, mounted on hips, hand-operated in use
Optional hand armaments: mega beam rifle, powered by rechargeable energy cap; mega beam shield
Technical and Historical Notes
One of several "powered up" variants of the basic LM314V21 Victory 2 Gundam, the League Militaire's LM314V23/24 V2 Assault-Buster Gundam combined the mega beam cannon of the LM314V23 V2 Buster Gundam and the offensive/defensive capabilities of the LM312V24 V2 Assault Gundam for increased offensive power. This variant was created by League Militaire engineers as a stopgap to keep up with the increasing number of high performance Zanscare mobile suits. However, equipping both the mega beam cannon and the armor plates significantly cut down the speed of the V2 Assault-Buster Gundam, making its maximum acceleration less than that of the basic LM314V21 Victory 2 Gundam.
Miscellaneous Information
Pilot: Uso Evin
Appearances: Mobile Suit Victory Gundam; Mobile Suit Gundam: Gundam Vs. Gundam; Mobile Suit Gundam: Gundam Vs. Gundam Next
Original mechanical designer: Hajime Katoki
Lineart
Beam rifle
Beam saber
Beam shield
Head/targeting sensor
เครดิต http://www.mahq.net/Mecha/gundam/v/lm314v23-24.htm
มาที่ข้อมูลสีที่ใช้ในงานครั้งนี้ครับ(กระป๋องทั้งนั้น)
รองพื้นพลาสติก WIN
CANDY RED WIN
CANDY BULE WIN
CANDY GREEN WIN
Leyland p-9 Gold
PYLAC  H-30 Black Gray met เทาดำเมท
ล้างสีโครเมียม ออก BY ไฮเตอร์
ตัดเส้น BY SAKURA FIMGA 0.05
โมตัวนี้ผมตั้งใจที่จะทำออกมาเป็นV2 โหมด Assault Buster อย่างเดียวทำเลยไม่พ่นส่วนที่จะแปลงเป็นเครื่องบินหรือส่วนอื่นๆของAssault และส่วนของ Busterครับ
มาเริ่มกันเลยดีกว่าครับ
โม ตัวนี้ผมผสมระหว่างของแท้และของจีนครับ
จบละครับ
สุดท้ายนี้
1.
(ลุงครับออกตัวนี้มาให้ผมหน่อยเถอะครับ)
2. งานนี้ผมใช้สีกระป๋อง งานที่ออกมาอาจจะมีส่วนที่จะดูเหมือนว่าแต่จะหนา เพราะคุมแรงกดลำบากนะครับอันนี้ยอมรับครับ
แถมของดองที่เตรียมทำออกมาครับ แต่สงสัยคงจะได้ดองอีกนาน :icondisapp:
« แก้ไขครั้งสุดท้าย: สิงหาคม 29, 2010, 08:48:54 pm โดย thebeer »
Re: [หมายศาลท้าดวล]V2 Assault Metalic Buster Gundam
« ตอบกลับ #1 เมื่อ: สิงหาคม 29, 2010, 08:50:34 pm »
เงาดีครับ สวยดี  รอดไปอีก 1 คน
............  ส่วน V2  MG ผมกลัวจะแยก V2 Assault , V2 Buster  แล้วก็ V2 แถมเอฟเฟคปีกแสง  อย่างละกล่องน่ะสิครับ  :iconcry:
ออฟไลน์ patsawat
« ตอบกลับ #2 เมื่อ: สิงหาคม 29, 2010, 08:59:11 pm »
ชอบสีทองมากเลยครับสวยดี  :iconshy2:
« ตอบกลับ #3 เมื่อ: สิงหาคม 29, 2010, 09:07:47 pm »
เงาแว๊บๆ
ต้องเอามาทำบ้างล่ะ..
อุดขัดแล้วนิ :iconwinks:
« ตอบกลับ #4 เมื่อ: สิงหาคม 29, 2010, 09:12:35 pm »
ทำออกมาแล้วนี่แยกไม่ออกเลยอันไหนแท้อันไหนจีน แจ่มไปหมด :iconsmile:
ออฟไลน์ wateya_rouge
  • กระทู้: 745
  • ^^'' it,Me
« ตอบกลับ #5 เมื่อ: สิงหาคม 30, 2010, 04:38:09 am »
แหล่มมม เลยครับ เหมือนเป็นของพรีเมี่ยมม สุดเจ๋งเลย  :iconvsign:
แต่ชอบรูปกล่อง ถ้าออกมาจริงละ?
Thailand only !!
ออฟไลน์ nongnoojoe
  • กระทู้: 330
  • มีตังแค่layland T-T
« ตอบกลับ #6 เมื่อ: สิงหาคม 30, 2010, 06:26:54 am »
สวยครับ ผมชอบสไตล์อาวุธหนักๆอย่างนี้อยู่ด้วย^^~
ปล.รอmgตัวนี้อยู่เหมือนกันครับ แต่ไม่อยากให้มันออกเป็นแบบแพ๊คเสริมนะ กลัวโดนหักหลัง
ออฟไลน์ Libra Gundam
  • กระทู้: 62
  • I'm a Gundam
« ตอบกลับ #7 เมื่อ: สิงหาคม 30, 2010, 07:52:16 am »
รูปหน้ากล่อง MG ทำเองเหรอครับเนี่ย เห็นแล้ว อยาก :iconfreak: :iconnasty:
ออฟไลน์ ong90
  • กระทู้: 682
  • sweet mother of mercy !!
« ตอบกลับ #8 เมื่อ: สิงหาคม 30, 2010, 11:49:27 am »
พี่เบียร์หายไปนาน กลับมายังงสีสไตล์แคนดี้ไว้เดหมือนเคยเลยนะพี่
ปอลิง.ตอนนี้ผมเรียนอาร์ตแล้วนะพี่
Sail To The New World
ออฟไลน์ ReJInA
  • กระทู้: 1,375
  • นี้มันโดนัทส่วนของชั้นนะ!!
« ตอบกลับ #9 เมื่อ: สิงหาคม 30, 2010, 12:20:44 pm »
หน้าตาเหมือนของจีนเลย 55 สีแบบนี้ดูรายละเอียดไม่ค่อยเห็นแฮะ
